Ansys Learning Forum Forums Installation and Licensing Ansys Products CO2 dissolving in water using Eulerian Model Phase Interactions Reply To: CO2 dissolving in water using Eulerian Model Phase Interactions
Yes. Fluent doesn't know what a gas or liquid is, so for phase change the "from" and "to" phases are important. The enthalpy is then used to work out the energy balance. Note, the disolution energy is different from the latent heat so you may need to check the material properties.
