Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › best tool for mesh export › Reply To: best tool for mesh export
peteroznewman
The following method is a good mesh export method. Unfortunately, the Student license limits apply to Nastran File Export. I suggest you find an Ansys Research license somewhere at your university so you can export the mesh using a full Ansys license.
In Workbench, create a Modal analysis. In Mechanical, mesh the body. You might need to click on Mesh and set the Element Order to Linear if that is a requirement for actran. Click on Modal in the outline and on the Environment context tab, use the Export Nastran File button to write out the model as a .dat file.  You should be able to import that into actran.  If there are issues, you can delete some of the initial lines of text in the file above the line that says BEGIN BULK and delete the last line that says ENDDATA.
