Ansys Learning Forum Forums Discuss Simulation Electronics Seeking help from experts, related to optimization design of HFSS, setting optim Reply To: Seeking help from experts, related to optimization design of HFSS, setting optim
Praneeth
Thank you for reaching out to the Ansys Learning Forum. Your patience on this issue is much appreciated.
I am confused by your statements. The optimization tries to achieve the goal by changing the variables specified. In your case, you are stating that "s" has to be changed during optimization without including it in optimization. This is not possible.
However, you can do two optimization setups separately - with the two values of "s" and then see the difference in the attained result after the optimization.
For more detailed information on optimization, please refer "Setting Up an Optimization Analysis" section of the HFSS help document available under the Help menu.
Best regards,
Praneeth.
