Ansys Learning Forum Forums Discuss Simulation General Mechanical Meshing with lots of contact regions Reply To: Meshing with lots of contact regions
Aniket Chavan
You can start with the errors you are getting while meshing, as you are seeing contacts, mostly the faces are not shared so there should not be an issue of small imprints, try different methods to mesh and see which one succeeds.
You can right-click on errors, and show problematic geometry to find issues in the model too.
-Aniket
Forum Rules & Guidelines
