Ansys Learning Forum Forums Discuss Simulation General Mechanical Selection logic In apdl Reply To: Selection logic In apdl
guy-hermann.youdom-yimbi.1
I tried to use the method that you have proposed but that doesn't work too.
It works only when the dependent node applies is the first one. If I put another number I got the same issue saying that the independent node is not selected.
Is there something else that I could try? Thanks in advanceÂ
