Ansys Learning Forum Forums Discuss Simulation General Mechanical FSUM in ANSYS Mechanical Reply To: FSUM in ANSYS Mechanical
dlooman
You can scope a Force Reaction and a Moment Reaction to a Surface (Construction Geometry) to get the force and moment at an arbitrary location without creating contact or a joint.  You will need to set Nodal Forces output to Yes.  For the Moment Reaction, specify Orientation to the coordinate system name used to locate the Surface and Summation to Orientation System.
