Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › The nodal solution for displacement command is not giving me a coloured plot › Reply To: The nodal solution for displacement command is not giving me a coloured plot
danielshaw
Is the model constructed using line elements (probably beams)?  If so, you may need to use the /ESHAPE command to show the elements and the contours.
