Ansys Learning Forum Forums Discuss Simulation General Mechanical solution information is not available Reply To: solution information is not available
Akshay Maniyar
Are you able to see other outputs like solver output or participation factor? Can you share the settings you are using for the command snippet?
Thanks,
Akshay Maniyar
