Sampat Kumar
Hi galaxy,
If you want to save .DB file then you can extract .DB file by Go to Ansys Mechanical--> Analysis Setting--> Save MAPDL DB file to yes--> Click on Solution--> Open Solver directory--> Find the .DB file.
I doubt that there is a method to save.DB file, as you indicated in the illustration, maybe someone can explain to you in the comment if this is possible as you attached in the image. Using the save archive option you attached to the image, you may save the file as an archive file and send it via email.
Sampat
