Ansys Learning Forum › Forums › Discuss Simulation › Fluids › EDC modelling › Reply To: EDC modelling
December 2, 2023 at 10:38 am
Hello Ren,Â
I tried the methods you mentioned but for both EDM and EDM+Relax to Chemical Equilibrium, i could not get the results. From EDM to EDC, fluent closed without any reason after some iterations or solution diverged. From EDM+Relax to Chemical Equilibrium to EDC, the temperature in the combustor gradually decreased and the i think the flame extinguished. Can you share your suggestion for these situations.Â
Or, can i use finite-rate/eddy dissipation model for my case? can i use a detailed reaction mechanism with this model? if yes, is the modelling easier with this model than EDC.Â
Thanks, with my best regards.Â
