Ansys Learning Forum Forums Discuss Simulation LS Dyna Error with SN curve Reply To: Error with SN curve
javat33489
>>go to "EleTol" and choose "Ident", then in "Identify" pick "Element", and then "Shell" (or any other element type that you are interested). Then click any element in the model, the ID of the element will pop up.
Okay, I got that.
But how can you remove elements from *DATABASE_HISTORY_SOLID_SET? This map contains information about the solids. Maybe you made a typo Sir?
