Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Segmentation (fault) error › Reply To: Segmentation (fault) error
December 1, 2023 at 3:48 pm
All the cases except 30kph & double-precision is terminated with forrtl: severe (174): SIGSEGV, segmentation fault occurred message. So, the FE model (30kph & double-precision) can run this case and terminate normally, but as I mentioned before when it comes to increasing the speed for the same case this message terminates the solution.
Can you please express maybe you can see NaN errors or number of nodes has out-of-rage forces this further and your solution?
Can not I ask for a support as an academic customer?
Eray
