Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Segmentation (fault) error › Reply To: Segmentation (fault) error
Alex Rycman
Thanks you for the update.
Did the termination error has change? Is is still forrtl: severe (174): SIGSEGV, segmentation fault occurred, or maybe you can see NaN errors or number of nodes has out-of-rage forces?
I will suggest to simplify the model as much as possible so those simulations are going to run to compleation. Once the model terminates normally, then you can add complexity. That way you can determine what is causing a segmentation error and look at this keyword more closely.
If you are a commercial customer, you can create a support case and we will have a look:
customer.ansys.com
Note that Ansys employees are not allowed to upload and download files on the Ansys Forum.
Alex.
