Ansys Learning Forum › Forums › Discuss Simulation › Fluids › What does it mean by ‘Warning: zone of type interior found between different solids!’? › Reply To: What does it mean by ‘Warning: zone of type interior found between different solids!’?
December 1, 2023 at 1:17 pm
Divergence is a different issue, and mostly likely linked to the mesh or solver settings.Â
As you have two materials mixing you must use the species model. The cell zone contains the "mixture-template" and when you initialise you then need to patch species to suit.Â
