Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Designmodeller round corner › Reply To: Designmodeller round corner
Sampat Kumar
Hi Elena,
The illustration doesn’t make it clear where you want to draw the rounded corner between the two triangles. To help you comprehend the part better, you can use a drawing to highlight it.
To do this, I would advise you to use the variable radius option. Kindly give this a try and let me know if it doesn’t meet your requirements.
As keyur correctly pointed out, You may perform this CAD operation considerably better by using the SpaceClaim or Discovery tool.
Sampat
