Ansys Learning Forum Forums Discuss Simulation LS Dyna Error with SN curve Reply To: Error with SN curve
Yun Huang
Hi, to get the ID of the nodes or elements, one can use LS-PrePOST like below.
go to "EleTol" and choose "Ident", then in "Identify" pick "Element", and then "Shell" (or any other element type that you are interested). Then click any element in the model, the ID of the element will pop up.
To remove elements from *DATABASE_HISTORY_SOLID_SET, one can edit the keyword file using "vi" or "notepad". 1) find *DATABASE_HISTORY_SOLID_SET. 2) Remove those element IDs under *DATABASE_HISTORY_SOLID_SET and 3) save the keyword file.
If you need further help, can you please send email to lstsupport@ansys.com? This can guarantee that each question or support need is tracked and is answered in time. Thanks.
