Ansys Learning Forum Forums Discuss Simulation Electronics how to set s-parameter reference import to Designer SI Reply To: how to set s-parameter reference import to Designer SI
Dan Dvorscak
Hello Byeonggeon,
There are very few reasons to use anything other than the implied reference to ground option. Given that s-parameters are a loop inductance model which includes the full return path in each entry, the only reasonable behavior for the reference nodes is to tie them to SPICE node 0, or ground as we often refer to it. The implied reference to ground will save you from having to tie a common reference pin, or indifidual reference pins to ground. I can't remember the last time I've seen a DDR/eye diagram simulation use anything than the implied reference to ground. That optoin is the default for good reason.
Best regards,
-DanÂ
