Ansys Learning Forum Forums Discuss Simulation Fluids What does it mean by ‘Warning: zone of type interior found between different solids!’? Reply To: What does it mean by ‘Warning: zone of type interior found between different solids!’?
Ayushman Srivastava
I have a shock tube. driver section of the shock tube is filled with helium at 0.9 MPa and the driven section is filled with air at atmospheric pressure. the diaphragm is there which separates the driver and driven section with each other. diaphragm ruptures and helium and air mixes with each other. shock wave then generates. How to remove that warning message and how to stop residual curves from diverging?
