Ansys Learning Forum Forums Discuss Simulation General Mechanical Selection logic In apdl Reply To: Selection logic In apdl
dlooman
If you issued allsel before the cerig command how is it possible that the independent node wasn't selected!?  If you say there is a one to one correspondence between the element real constant set number and the element type numbers you specified, the only explanation is that the second one was a reselect.  Why didn't you use ESEL,s for the type numbers like you did for the real constant numbers?
