Ansys Learning Forum Forums Discuss Simulation General Mechanical Selection logic In apdl Reply To: Selection logic In apdl
guy-hermann.youdom-yimbi.1
Does that means that I have to select that node before issuing the CERIG command?
By the way I have issued ALLSEL before the CERIG command.
For the selection problem, according to what I read on Ansys documentation the reselect command shouldn't change.
Is it possible that if we issue a reselect command with a result which doesn't change the set already selected we got problems?
ThanksÂ
