Ansys Learning Forum Forums Discuss Simulation Fluids Mass flow rate data extraction from Fluent. Reply To: Mass flow rate data extraction from Fluent.
No need to monitor, just create the report and check the value. This is to get an idea of whether there is flow, ie if there's a problem with the model rather than the report. Similarly run the mass flow report at the current time and see what value is posted to the TUI.
