Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Questions regarding an example › Reply To: Questions regarding an example
Niki Papachristou
Hi Mariah,
Thank you for the clarification. I believe that for the solar cell example is set up this way to cover both aspects. The fact that it is recomended to put the monitor infront of the source when the planewave has an angle does not cancel the case were the angle is 0. This way the users will be able to use the same example when they will need to inject the source with an angle. As for the 1+transmission equation in this case, I think that the transmission has negative values in its data base already.
Kind Regards,
Niki
