Ansys Learning Forum Forums Discuss Simulation Fluids Specifying mooring line angle in ANSYS AQWA Reply To: Specifying mooring line angle in ANSYS AQWA
Mike Pettit
You should be able to do this using Fixed Point Groups (available from Release 2022 R2). A Fixed Point Group allows you to create a circular pattern of fixed (anchor) points, at equally spaced angular intervals. You can then Duplicate the group, and apply an RZ rotation to the duplicates, to build up the anchor points for your mooring system. For example:
This was created using Fixed Point Groups without any need to manually calculate the anchor point positions.
Linear or rectangular patterns can also be generated, or you can import a CSV file of attachment point positions. Connection Point Groups offer the same functionality for Connection Points on the structure.
I hope this helps.
Mike
