Ansys Learning Forum Forums Discuss Simulation Photonics Problem when importing the STL file from solidworks into the FDTD Reply To: Problem when importing the STL file from solidworks into the FDTD
Niki Papachristou
Hi Kawshik,
Thank you for reaching out to us, unfortunately it is not possible to attach files on this post. Have you gone through the notes int this article: STL import - Simulation object? Also, did you try importing you file with the command:  stlimport - Script command?
Kind Regards,
Niki
