Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Grouping elements with a command in APDL › Reply To: Grouping elements with a command in APDL
November 29, 2023 at 2:18 pm
dlooman
There is no *get of element temperature mentioned in the *get documentation. It appears you would need to be in post1, create an element table for temp (etab,temp,temp) and then *get the etable item. If you can't be in post1 when you issue these commands you could *get one of the nodes of the element and *get its temperature.Â
Also, I'm pretty sure the *if command needs to end with then, *if, temp_val, le, 20,then. You could replace the two *if commands with one:  *if, temp_val, le, 20,and,temp_val,gt,0,then
