Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Mass flow rate data extraction from Fluent. › Reply To: Mass flow rate data extraction from Fluent.
rajendrapor
Hi Rob. Thanks for the quick response.
I am using a sinusoidal pressure inlet udf as BC for my system. I want to extract the data at a particular cross section. But it remains at zero with the simulation time (as attached in the figure). By plotting the images, what exactly do you mean? Should I plot the contours?
