Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Particle blast method (PBM) › Reply To: Particle blast method (PBM)
Ram Gopisetti
Hi
We [ ANSYS engineers ] cannot share any files here in this platform. However, may be others might post it if they have.
Track the pressure counters, but since air being void most of the method will be limited try to use ALE as it need air domain requirement and then use DEM.
It would be best if you get started and then post you issue here than expecting a fully or developed solution here.
check the following studies
https://lsdyna.ansys.com/wp-content/uploads/sites/2/attachments/particle-blast-method-pbm-for-the-simulation-of-blast-loading.pdf
https://www.dynalook.com/conferences/10th-european-ls-dyna-conference/7%20Simulation%20III%20-%20Blast-Penetration/03-Schwer-SchwerEngineering-P.pdf
Cheers, Ram
