Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Meshing does not load all the surfaces › Reply To: Meshing does not load all the surfaces
Federico
as per my response in your other post: Boolean (subtract) between solid body (surrounding ambient) and surface bodies (ansys.com), you need to work with bodies and volumes to bring your model to Fluent. This can be done in Design Modeler, but I'd suggest using Discovery/SpaceClaim if you have access to it.
