Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Update-Dynamic-Mesh failed. Negative cell volume detected › Reply To: Update-Dynamic-Mesh failed. Negative cell volume detected
Cláudio Corrêa
I’m trying to reproduce the flow around a mechanically controlled door tutorial ((846) Ansys Fluent: Flow Around A Mechanically Controlled Door. - YouTube)  and my simulation crashed after a few seconds with the error message “Update-Dynamic-Mesh failed. Negative cell volume detected”.
Analysing the results in CFD-Post, the problem occurs in the valve movement because it literally enters the mesh.
How do I fix the error?
Attached is a picture of the movement of the valve.
