Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Laser Surface melting in fluent using udf › Reply To: Laser Surface melting in fluent using udf
November 28, 2023 at 6:04 pm
x[0]
is the x-coordinate of the face centroid.x[1]
is the y-coordinate of the face centroid.x_pos
is a variable representing the current position of the heat source along the x-direction, which is updated based on the velocity and current simulation time (vel * current_time
).A
,B
, andr
are constants in your equation.F_PROFILE(f, thread, position)
sets the temperature profile on the face.
Breaking down the equation:
(x[0] - x_pos)
represents the distance of the face centroid from the current x-position of the heat source.(pow((x[0] - x_pos), 2.) + pow(x[1], 2.))
is the square of the Euclidean distance of the face centroid from the current position of the heat source in both x and y directions.pow(r, 2.)
is the square of the radiusr
.B * (pow((x[0] - x_pos), 2.) + pow(x[1], 2.)) / pow(r, 2.)
is the argument inside the exponential term.exp(...)
calculates the exponential function.
