Ansys Learning Forum Forums Installation and Licensing Ansys Products RSM Error when sending test job to HPC SLURM – Failed to find Cluster Queue Reply To: RSM Error when sending test job to HPC SLURM – Failed to find Cluster Queue
MangeshANSYS
If this the first time RSM is being configured in your enrironment?
Or are there other users or prior versions which are working correctly ?
some things to double check:
On linux say in .bashrc or similar is the variable AWP_ROOT232 set ?
From Windows if you run the below - when is the output of command below ? do you see the same output as when running sinfo on linux say in an interactive putty session? (please use your actual username and linux machine hostname when running this ocmmand)
plink.exe -batch -i "%KEYPATH%" your_actual_username@your_actual_linux_machine_name sinfo
