Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How solve the following problem? › Reply To: How solve the following problem?
November 28, 2023 at 3:27 pm
mrife
Hi Yu
Identify the error; figure out where in the input file the import was at the time of the error; address the input files mistake/typo/whatever.
The APDL command "C***,comment text" (without the quotes) will place a comment in the MAPDL output. If it is not obvious where in the input file the issue is located then you can start adding comments to the cdb file with text that would make sense to you.
