Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with mass matrix – APDL › Reply To: Problem with mass matrix – APDL
November 28, 2023 at 3:13 pm
Hi Diona
Why would the mass matrix be diagonal? My guess is that you are assuming a lumped mass formulation...if so please see the help on the Mechanical APDL command LUMPM. You may also want to read the MAPDL Theory Guide, chapter 12.5 (Element Reference -> Lumped Matrices) as there are some caveats to using this.
Mike
