Ansys Learning Forum Forums Discuss Simulation General Mechanical [Error] Unable to start the mechanical editor Reply To: [Error] Unable to start the mechanical editor
Sampat Kumar
This looks like Script error in the Ansys. As per your explanation, it looks like system specific.
For the initial resolution, please try to reseat the configuration in Ansys. clear %appdata% and %temp%  see whether the issue still occurs when you edit the model in the mechanical.
1.For clearing the %appdata% in your system. Open a file explorer and type %appdata% in the address bar. Locate the Ansys folder and rename it to Ansys.old.
2. For clearing the Temp data-Go to the Start Menu and open %temp% folder. Search for ‘.ansys’ folder and rename it to ‘.ansys.old’ then launch the application.
Sampat
