Ansys Learning Forum Forums Discuss Simulation Fluids Set up the flow solver Reply To: Set up the flow solver
Federico
Hello Aras,
there is a lot in your question. To compare your results with experimental data you need to closely match the conditions for that setup (e.g. the inlet turbulence conditions) and those results will also be influenced by your mesh resolution.
We have lots of resources in the Ansys Innovation Space of simulation lift and drag for airfoils. I'll invite you to consult those resources to get started.
Compressible Flow Over An Airfoil | Ansys Innovation Courses
Flow over an Airfoil using Ansys Workbench | Ansys Courses
Flow over an Aircraft Wing - ANSYS Innovation Courses
