Ansys Learning Forum Forums Discuss Simulation Electronics Simulation cavity having a gap with HFSS Reply To: Simulation cavity having a gap with HFSS
dushyant.marathe
Hi Hien,
Thanks for posting your query on Ansys Learning Forum.
I could understand that you are trying to simulate cylindrical cavity splitted into two halves alog z-axis and probably to create a split you are subtracting the thin box.
However, I would like to know which solution type in HFSS you are using for cavity simulation to get quality factor.
I would also request you to provide screen shots of splitted cavity, cavity before split and subtract operation from HFSS model tree.
Thank you.
