Ansys Learning Forum Forums Discuss Simulation Photonics Can’t add frequency domain field profile into structure group using script Reply To: Can’t add frequency domain field profile into structure group using script
Dev
Thanks for shairing more details:
Are you adding
”addprofile” in
Structure group? That could be the reason of error.
You won’t be able to add the profile monitor there. Its only for the structure . You can add monitors in analysis group. Or you can use any of the following options.
Option 1:
You can create an lsf file from Script file Editor on the right side of window and add profile monitor
Option 2:
add the monitor inside the model script.
I will recommend this course material: Ansys Lumerical Scripting – Learning Track | Ansys Innovation Courses
Please let me know this solve the problem.
Thanks and regards
Devika
