Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to set Pressure and Motion (Aqwa HD) object selection to “All” › Reply To: How to set Pressure and Motion (Aqwa HD) object selection to “All”
Mike Pettit
Firstly, please check that you have set up the geometry correctly - there should only be 2 structures in the Outline tree, which are the ship and the wall. In SpaceClaim (if you haven't done so already), you should select the surface bodies which make up each structure, form them into separate components (one for the ship, one for the wall), and set each component's 'Share Topology' option to 'Share'.
Then, in Aqwa Workbench, you need to set up the Hydrodynamic Diffraction Structure Selection. Please check that none of the structures appear in 'Structures to Exclude', then click on 'Interacting Structure Group 1'. Holding down the Ctrl key, select the ship and the wall in the main window, then click 'Apply'.
In the Pressures and Motions result you should then be able to set the 'Structure Selection' option to 'All', and the wave surface will be drawn around the whole interacting structure group.
I hope this helps.
Mike
