Ansys Learning Forum Forums Discuss Simulation LS Dyna Crashbox under different temperatures Reply To: Crashbox under different temperatures
Jim Day
Set NEIPH=5 (if solids) or NEIPS=5 (if shells) in *DATABASE_EXTENT_BINARY to write out 5 extra history variables.  The 5th such variable for MAT_015 is T – Troom.   Check the value of that variable to confirm its initial value is the initial temperature per *INITIAL_TEMPERATURE minus TR in *MAT_015.
