Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Extracting K, U and F from ansys › Reply To: Extracting K, U and F from ansys
jacopo.bardiani
Hi Mike and Tasos,
thank you very much for the support and the replies! Absolutely, I need the applied loads! My idea is to extract data (K, U and F) and then being able to solve U = K^(-1) * F with the same results provided by the software. After that, I'm going to create reduced order model.
For the second doubts of Mike, yes! I need something that "matches" the numbers of nodes I see in ANSYS, in order to control what I'm done. For instance, for node 1 in the model, the first raws and columns of K are corresponding to the dofs of the node 1. Same for F!
Let me know,
Jacopo
