Ansys Learning Forum Forums Discuss Simulation Fluids How to setting Free Decay Test in Ansys Aqwa Reply To: How to setting Free Decay Test in Ansys Aqwa
Shuangxing Du
A freely floating structure has no horizontal plane (surge, sway and yaw) hydrostatic stiffness, there is no way to do a sway freely decaying test for such model.  Please define the proper mooring system of this FOWT structure. As the mooring system may provide the stiffness along the horzontal plane directions, you may see the sway decaying time domain response. It may be even better if you can define the current drag coefficients for this structure, then the nonlinear viscous drag forces will be included in the freely decaying test.
