Ansys Learning Forum Forums Installation and Licensing Ansys Products Licensing – Request name does not exist in the licensing pool Reply To: Licensing – Request name does not exist in the licensing pool
ANSYS_MMadore
Yue Tang, it is trying to use a license which doesn't exist. You may be specifically trying to call the meba (Mechanical Enterprise Solver) license and it is not trying other licenses. You should try your solve process settings to see if you can modify your license settings to use a license you do have access to.
