Ansys Learning Forum Forums Discuss Simulation Systems Displacement convergence in System Coupling Reply To: Displacement convergence in System Coupling
Tasos Zacharakis
Hello Davide,
If you're encountering an issue where the system coupling has not yet converged, it could be due to a variety of factors.
One common cause is that the solution is not yet fully converged. Check this link : Error: update failed for the solution component in system coupling. The coupled update for system fluid flow (fluent) threw an exception. Update solution failed - Ansys Knowledge.
Another potential issue could be related to the stability of your FSI or 6DOF case. This link : How can I converge an unstable FSI or 6DOF case in Fluent - Ansys Knowledge, provides a comprehensive guide on how to use Fluent's Solution Stabilization for an FSI case or a 6DOF case. It includes information on how to identify instability, how to use solution stabilization, and how to adjust settings for optimal results.
I hope these guidelines will help you with your project.
Thank you,
Tasos
