Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Unpredictable Parameter Transformation Issue in ANSYS SpaceClaim › Reply To: Unpredictable Parameter Transformation Issue in ANSYS SpaceClaim
Charudatta Bandgar
Hello Charles,
If I understand correctly, you are trying to define parameter for an edge pull? What is the intension here? Instead of choosing the edge, if you select the face instead it should work.
Regards.
