Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Change in shape when looking at results › Reply To: Change in shape when looking at results
pv00170
These are beam elements attached to 3D solids. All connections are the same for all beams and it works properly for the rest.
I have tried the following:
  • use MPC as suggested
  • extracted the beams again (from zero)
  • delete the connection and duplicate from a beam which does not show this issue and assign it to the mentioned beams
but the problem is still there.
