Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Unexpected Fluent Crashes › Reply To: Unexpected Fluent Crashes
November 25, 2023 at 4:57 am
TingWangUNO
Thank you for your response,
The transcript shows nothing else; the case does not diverge, and the only error presented is the abnormal exit. The case can be reintialized from the autosave at timestep 5000, where it will run from timestep 5000 to timestep 10320 before crashing again. Â
If the case is reinitialized from the start after a system reboot, the problem will still persist.
