Ansys Learning Forum Forums Discuss Simulation Fluids How To Plot Angular Velocity — Wind Turbine, Fluent Reply To: How To Plot Angular Velocity — Wind Turbine, Fluent
Federico
Hello Nate,
the area-weigthed average tangential velocity will really only work for a circular motion of a cylindrical domain. If you know the radius and tangential velocity of this motion, you can work out the angular velocity. You really only need 1 point that has these two quantities over time. The area-averaging is only to reduce the noise in this calculation.
 You can read about how Tangential velocity is defined here: 41.2. Velocity Reporting Options (ansys.com)
In your case, with airfoils, I still recommend using the data from Motion History.
