Ansys Learning Forum Forums Discuss Simulation General Mechanical Change in shape when looking at results Reply To: Change in shape when looking at results
ashish.khemka
Please check if the parts are properly connected. You may try running a modal analysis as well. If the parts are shell bodies and bonded then check if you have used MPC algorithm for the contact. MPC algorithm gives proper result display for shell elements.
Ashish Khemka
