Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Ansys SpaceClaim Dimension bug › Reply To: Ansys SpaceClaim Dimension bug
Hello smjang
I'm using Spaceclaim 2022 R2 and still have the same bug with korean.
I found some solution and I think the problem caused by korean keyborad setting.
1. Move to windows setting - time & language - language and add English (United States) by click (+) button.
2. After the language installed you might find 한 (keyboard setting) at the bottom right of your windows taskbar next to the clock and date.
3. Switch to US Keyboard and try changing dimensions.
Once you do that then it will keep working as you change the keyboard back to korean.
But you should keep doing this routine everytime you run the spaceclaim.
I hope Ansys would fix the bug..
