Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › APDL code for a snippet in static analysis › Reply To: APDL code for a snippet in static analysis
javat33489
Contact doesn't suit me.
Look. I have rubber between two plates 1 and 2.
1.In the first step, the rubber is pulled to the left and all three parts (1 and 2 and the rubber are fixed), the bonded contact connects the rubber by the plane (highlighted in red).
2.In the second step, I need to remove the fixation from these three parts, and then the rubber will begin to move to the left, but at the same time it should pull plates 1 and 2 with it. When the rubber is stretched in the first step, it will become flat and the bonded contact will be lost (highlighted red).
So I need to find a way so that in the second step, when the fixation on the rubber and plates is removed, the rubber will drag the plates with it.
